I have a pretty basic block (circle around a number, only used in paper space) that refuses to change color. If I go into properties and change the color to white, it continues to display as cyan. If I change the color via BEDIT (I've tried changing it to bylayer, byblock, and straight up white with this method), it still displays as cyan. I've also tried changing my plot settings to try and force it to print black; I found a way to do so with some tinkering, but that also makes most of my other colored blocks print as black -- and of course, I need these other things to print in color. I do not have this problem with this block in other drawings.
Also, I would like to leave the block in tact if possible -- no exploding -- else I'll have many, many little circles that need to be exploded and changed manually. It seems like this should have a very simple solution, but I can't figure it out.
Any ideas on how I can fix this very frustrating issue? Thanks!
