Showing results for tags 'block rotate attribute'.
  1. From the attached image you can see what I'm talking about. (left=original, middle=ROTATE, right=PROPERTIES) When I rotate blocks using ROTATE command everything is fine, but when I rotate blocks using PROPERTIES my attributes get messed. I need to rotate several blocks at once with PROPERTIES, because I don't have time to rotate each one separately. The same thing happens when scaling blocks, but this was resolved using the command BSCALE in the command line.
