Showing results for tags 'by color'.
  1. Hi, I am trying something like this: (setq ed (entget (car (entsel)))) (setq lyr (cdr (assoc 8 ed))) (setq clr (cdr (assoc 62 ed))) How can I get a selection set based on layer and color of a given object? Something like: (setq objs (ssget "X" '((cons 8 lyr) (cons 62 clr)) ) ) [i know this is not working I write it just to give the idea.] and then change the objects' layer to "0" and color to 2. Thank you in advance tso
