Showing results for tags 'clean 3d'.
More search options
  1. Hi all I cant seem to get the clean command to do anything it asks whether i want [imprint/seParate solids/Shell/cLean/Check/Undo/eXit] so i type "L" it says select object i click the solid it says [imprint/seParate solids/Shell/cLean/Check/Undo/eXit] again... can anyone point me in the right direction? cheers Marcus
