Showing results for tags 'clipping boundaries'.
  1. Hello, I'm just re-familiarizing myself with AutoCAD after a four year stint as a CNC operator, and I'm trying to remember a little trick I used to know. I would like to clip an image file with multiple polylines as the clipping boundaries. The problem I'm having, however, is that there doesn't seem to be an "all-in-one" solution for this task. XCLIP only handles a single clipping boundary. So I tracked down "XClipM.lsp", which covers multiple clipping boundaries, but not arcs, circles, splines, etc. Then I tried CLIPIT. That handles the arcs and circles, but NOT multiple clipping boundaries. Are the developers of AutoCAD "special needs" students, or what? It seems completely obvious to me that these functions should all be integrated into one command, and it seems completely obvious that if you want to clip something with one boundary of one shape, you're probably eventually going to want to clip something with multiple boundaries of multiple shapes. Duh. Does anyone know of a solution or a .lsp that can handle this? Your expertise is greatly appreciated. AutoCAD 2013, BTW.
  2. Hi! Is there a way to use a clipping boundary on an OLE from excel? I've tried blocking it and then using xclip, but oddly it clips everything _except_ the OLE. Basically, I've got multiple tables I want to display throughout the drawing and I'd like them to be linked to a single excel, while still being embedded rather than linked to an external excel file. I've been able to use an excel OLE within blocks before to accomplish this for the same table repeated throughout a drawing, but I'm hitting a dead end for doing this with multiple tables. Thanks!
