Hi,
I am looking for some techniques regarding putting a block or any other geometrical object at certain length along a curved surface i.e an arc or spline.
I need to take a curve surface and put a block at 150mm. from the endpoint. The distance 150 mm. means arc length from the endpoint of the arc. I then break the two ends away from the arc and work on the remaining portion using divide command to place same blocks along predefined distance. I know this work. It is the first step, taking an arc distance of 150mm. from the endpoints which is difficult.
Attached you will find part of a project I am working on.
Thank you very much.
Nicolas
curve_study1.dwg
