I have a drawing set up but I only want the lines to be made sketchy using the visual styles editor. Theres blocks contained within the drawing which are messed up when made sketchy (they are trees so already have a sketchy appearance, problem is there is alot of them so would be time consuming to remove)
theres also a hatch patten for floor tiles and brick work within the drawing and the lines of the hatch are also made sketchy.
So basically I want a visual style but i want it to ignore blocks and hatches. does anyone know if this is possible. had a quick look around but not having much luck
