Showing results for tags 'increment numbering'.
  1. Hi guys, I am new to LISP and CAD customization at all, so what I am asking for is a guide where to look and how to approach my problem. Sorry for my English, I am not a native speaker. My goal is to create button which will insert a block into my drawing (I know how to do that), block is a simple circle with a number, which represent a reference for some element, a stud for example. What it should do.... 1) click a my made button which start inserting a block with a midpoint (done) 2) click in a drawing and insert the block to a anyplace I want (dont know how to continue inserting without hitting the button again) 3) inserting the block will still continue but now it will be second one(3rd,4th etc.) and the number in a circle will be increasing by 1 4) I would like to specify from which number the increment numbering should start.
  2. Hello, I am new to AutoLISP world. I am trying to write a code which will edit attribute in incremental numbering with each click on attribute. The easiest way command for it is "ATTIPEDIT". But I failed use ATTIPEDIT in LISP. Pls help to run this code: (defun c:DTAG () (princ "\n AUTOMATIC ATTRIBUTE SEQUENTIAL NUMBERING") (setq no (getint "\n Enter Starting Number : ")) (setq pt T) (while pt (setq notxt (itoa no)) (setq pt (getpoint (strcat "\n Select Attribute to be changed ( "notxt" ) < exit > : "))) (if pt (progn (command "_.ATTIPEDIT" pt notxt) (setq no (+ no 1)) ) (princ "\n Routine terminated normally by User") ) ) (setvar "CMDECHO" ocmd) (setq *error* olderr) ;;Restore old error handler (princ) ) PFA ACAD file to test. Try putting incremental numbers in place of "0". HVAC Dynamic Blocks 09.02.2018.dwg
