Showing results for tags 'layers lisp on off'.
  1. I need to overwrite layers from so many drawings. I thought it could be solved with this code: (setq layers (list "005_DIMENSION" "off" "thaw" "unlock" "255" "255" "255" "Continuous" "-3" "CHBL_01" "dimensions")) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 (car layers)) (cons 70 0) ) ) (setq layers (cdr layers)) (if (= (car layers) "on") (setq test ':vlax-true) (setq test ':vlax-false) ) (vla-put-layeron (vlax-ename->vla-object (tblobjname "LAYER" (car layers)) ) (princ test) ) The proble at the end is that I can not /read/add the value from a symbol in my lisp (it is called test) Can anybody help me please?
