Showing results for tags 'line vertex z'.
  1. hello, Hope this find you great. I have something strange there, nobody for instance find the solution. A case for autocad performer! The lines apear with different width, but they have the same properties (layers, pen , thickness etc...). AND THERE s NO supperposed lines. The only thing different is one have vertex z, and the other only x and y. Have tried following solutions: match properties, flatten image (all z with 0), repair archive with audit, regen copies past theses line in a new archive, print with different printers... nothing change. Something more strange there, when i draw line they are with x and y vertex. When i draw circle it have also z vertex, wich made another apprarence... . Any ideas? thanks at all for your support.
