Showing results for tags 'loop select'.
  1. Following through an online Autodesk tutorial I can across the following In the sketch and in my case, I was unable to select all the edges by just selecting one of them. However, there are no Loop Select and Constrain Offset in the context menu. Does any one what is the overflow menu and where to check the Loop select ad Constrain Offset? Thanks in advance.
