Showing results for tags 'michaels corner #95'.
Okay, let me lay out the information I have and hopefully someone can make sense of it: 1) When "explode" is typed at the command line, or picked from the modify tab on the ribbon, or selected from the modify pulldown, a message appears "unknown command." 2) In the Alias Edit there is no "xplode" command. 3) I have loaded partial customization files so that I can retain my pulldown menus (as per Michael's Corner #95), but have not changed anything else with the CUI. 4) In the CUI, there is an explode command showing a source of ADT_Modify. The area to the left of the command is now blank, but a co-workers workstation (which is working satisfactorily) shows a question mark to the left. 5) There is another explode command with the "exploded box" to the left showing a source of ACA. 6) In the Alias Edit the shortcut key "x" shows being linked to AutoCAD Command "explode." But as mentioned before "explode" selected any other way is unrecognized. I understand the differences between "explode," "xplode," and "burst." But it appears that for some reason I no longer have the ability to use "explode." I have temporarily modified my Alias Edit for "x" to link to "xplode," but I would really like to still be able to use the "explode" command sometimes too. Any suggestions out there?? Thanks.
- 5 replies
- michaels corner #95
- explode
