Showing results for tags 'multiple layer change'.
  1. Hi there, here a thing I want the do with LISP: I want to change multiple Objects with different Layers, that each Layer change to a different Layer. Example: Select entities with (ssget "_:L" '((8 . "Layername1, Layername2, etc"))) Now change Layer: Layername1 → 1_Layername1 Layername2 → 1_Layername2 I don't want to select each entity and than change its Layer. I want to do all entities at the same time with one command.
