Showing results for tags 'set insert block scale'.
  1. Is there any way with Autolisp to allow the user to set the insert scale of a block? So that all the blocks inserted have the same value until another size is desired. What I do now is insert a block with insert command. Check- Specify On-screen & Uniform scale in the Scale group box. Then type something like 96. Or use a toolbar object to insert, then scale as needed. Usually I draw in full scale then adjust the View port accordingly. But occasionally I need to have 2 diff scaled objects in the relatively similar area. Any ideas?
