Hi,
My first post, any help would be appreciated. I have to create a dynamic block for our overhead cupboards. I've tried to do it myself but the solution is not forth coming and the brain is starting to hurt.
I've attached a drawing to better illustrate what i want to do. It has the old style doors but i will create a new DB for the new style.
The OHC will be inserted with the top left point. I then want to stretch the top right point to the appropiate length and have the 3 doors strech equally. The gap between the doors will be 22mm and must not change. The end gaps will vary because of door size but will stay within 31.2 mm to 32.7 mm (As close to 32mm as possible). Also the rh edge of the water level guages need to be 58mm from the rh door edge. Hope it made sense.
Thanks Guys
3 DOOR OHC.dwg
