Showing results for tags 'visibility parameter'.
  1. Hi all, It`s been a while. Does anyone have a lisp to show on a leader the visibility state of a dynamic block? Cheers
  2. Hey guys! Ideal flow: Select blocks > run lisp > Visibility parameter (called "Buffer Ring") toggled to state called "On" > LineWorkShrinkWrap runs on selected blocks > Visibility parameter toggled back to "Off" Lee Mac's code here looks like a good start. Trying to learn, so walking me through whatever you do would be appreciated. Thanks!
  3. Hello, I found this to interesting and proven on having more than 1 Visibility Parameter. The below link redirects to a page of 2 guys work Andrey Lazebny and Nikolay Poleshchuk. http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm Their block works perfectly, unfortunatelly I was unable to repeat their work. I can't create more than 1 Visibility Parameter on either 2007 or 2012 AutoCAD. From some reason it does not want to use the defun commands. CAD loads it with no errors, both lsp files but once I'm trying to run those commands (visibility_add or move-parameter) it just gives me Unknown Command error. I'm not good in Auto LISP, but does anyone knows how to make this piece of art to work ? Maybe it's a AutoCAD version issue, but like described earlier I was doing the test on both 2007 and 2012 ver.
