Showing results for tags 'visual style'.
  1. In Revit 2013, set to Mechanical Discipline + Hidden visual style it's partially showing certain parts and looks half finished: When I change to Coordination you can see that it looks correct. No lines are missing etc: I need it on Mechanical to show the Duct centrelines (at Hidden visual style). Does anyone know 1) what's causing this and 2) if there's an easy way to fix it? (I thought I'd be able to review each discipline settings but I don't believe you can do that, unless someone tells me otherwise.) Thanks a bunch!
