Showing results for tags 'visual styles'.
On an assembly, is it possible to see one piece as wireframe and the rest as shaded?. I change visual styles but it applies on the whole structure, dont know if is possible to have different styles on an assembly for different pieces.
Visual Styles on Selected items only
mountain1985 posted a topic in AutoCAD Drawing Management & Output
I have a drawing set up but I only want the lines to be made sketchy using the visual styles editor. Theres blocks contained within the drawing which are messed up when made sketchy (they are trees so already have a sketchy appearance, problem is there is alot of them so would be time consuming to remove) theres also a hatch patten for floor tiles and brick work within the drawing and the lines of the hatch are also made sketchy. So basically I want a visual style but i want it to ignore blocks and hatches. does anyone know if this is possible. had a quick look around but not having much luck- 7 replies
- sketchy
- ignore blocks
