cvriv.charles Posted April 29, 2009 Posted April 29, 2009 I did some research on steel square tubes. I read that the tubes havea tolerance of +-.1 and that the manufactures are very good at making the minimum. Most likely to save money. Do I model the stated size or the actual size? Quote
ReMark Posted April 29, 2009 Posted April 29, 2009 We use stated size as the variable is so slight. Quote
cvriv.charles Posted April 29, 2009 Author Posted April 29, 2009 Ok. Thats what I thought you guys would say. It's just that 0.1 doesn't seem all that slight to me:\ Thanks. Quote
ReMark Posted April 29, 2009 Posted April 29, 2009 Ok. Thats what I thought you guys would say. It's just that 0.1 doesn't seem all that slight to me:\ Thanks. And that why they are called dimensional tolerances. Precise control of tolerances in steel forming/cooling is not economically feasible. Unless the demands of a project justify the additional cost then there is no reason to expect absolute perfection. Quote
