onkelbob Posted May 1, 2009 Share Posted May 1, 2009 Can solids be created from 3d faces? I have a wedge that is irregular, One end is smaller that the other end. I don't know ow to extrude it and I can easily make 3d faces.What is the easiest way to create this solid? Quote Link to comment Share on other sites More sharing options...
onkelbob Posted May 1, 2009 Author Share Posted May 1, 2009 I am using 2006 and CONVTOSOLID is unknown Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 1, 2009 Share Posted May 1, 2009 there is a lisp on here thats meshtosolid. you can use it to create a solid from a mesh surface. Also with your wedge you can create a solid then use taper face to alter the angles of each side individually. Quote Link to comment Share on other sites More sharing options...
