FazBear Posted May 5, 2009 Share Posted May 5, 2009 Morning All I have a lisp that will run a series of commands on multiple layouts which have standard layout names, problem is i am switching to each layout by specifying the layout name, but occasionally some of the layouts will be removed. so the lisp is running commands in error on those missing layouts. Does anyone know a better method than whay i am using. i was thinking somthing like (if (= [layoutname] "500") (command "-layout" "s" "500")) Cheers all. Quote Link to comment Share on other sites More sharing options...
Patrick_35 Posted May 5, 2009 Share Posted May 5, 2009 Hi (member "500" (layoutlist)) And you can use ctab @+ Quote Link to comment Share on other sites More sharing options...
FazBear Posted May 5, 2009 Author Share Posted May 5, 2009 Patrick Thank you, did the trick!! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 5, 2009 Share Posted May 5, 2009 As Patrick says, its better to use CTAB (if the version has it), so: (if (member "500" (layoutlist)) (setvar "CTAB" "500")) Quote Link to comment Share on other sites More sharing options...
