Ritch7 Posted May 5, 2009 Posted May 5, 2009 hi everyone, i have a pdf image in autocad with some stuff in acad how do i make it so the info appears in front of the image so i can see it rarther then the pdf overlapping everything? i can't seem to find the bring to front option?? Quote
feargt Posted May 5, 2009 Posted May 5, 2009 DRAWORDER command then select the the pdf and hit enter (the default option will send it to the back but read the command line to see the other options) Also if you right click on another toolbar you should see a list of all the available toolbars, select the draworder toolbar. The command you were looking for should be on this Quote
