Chandni Posted May 7, 2009 Posted May 7, 2009 When a drawing is xreffed using the bind command - in the Layer Properties Manager all the layers are grouped using the file name. I was wondering if any one has xreffed using the bind command, then most layers are grouped (all beginning with the file name) but 1 or 2 are not grouped and retain the original layer name.. Is this possible? If so why does that happen? Quote
