Guest LElkins Posted February 6, 2008 Posted February 6, 2008 Hi guys and gals, Just a quicky on the fly here. If a drawing created using full AutoCAD, with true colors used is opened in AutoCAD LT, how will the colors display/behave? Many thanks in advance for any comments. Cheers Quote
Hedgehog Posted February 6, 2008 Posted February 6, 2008 True colours?... AFAIK the Modelspace colour system is exactly the same (unless you're rendering of course) Quote
Guest LElkins Posted February 6, 2008 Posted February 6, 2008 If you go into color selection for layers, in autocad you get the tabs Index Color, True Color and Color Books. In LT you only have index colors. If i set a color in full cad to a true color, how would that behave when opened in LT? Quote
Hedgehog Posted February 6, 2008 Posted February 6, 2008 Ah yes... probably to the nearest increment... similar to reducing a photo to only 256 colours. Quote
Guest LElkins Posted February 6, 2008 Posted February 6, 2008 Dam it. Looks like the alternative is to then use an stb file, and create a style for each possible true color, 255*255*255=16581375 .... or maybe not. Quote
rkmcswain Posted February 6, 2008 Posted February 6, 2008 If you go into color selection for layers, in autocad you get the tabs Index Color, True Color and Color Books. In LT you only have index colors.If i set a color in full cad to a true color, how would that behave when opened in LT? My guess is that it would be fine. You just wouldn't be able to change it to another true color. Sort of like you can't attach an image in LT, but if you open a drawing created with AutoCAD that has an image attached, it's OK. Quote
e.fenske Posted April 6, 2009 Posted April 6, 2009 what exactly is an stb file? and how are they created? Does anyone know of a patch/extension that allows colorbooks to be used in LT 2005? Quote
