hi i'm having trouble trying to write a template txt file to extract to CDF. can anyone point me in the right direction
Look here for help on Attext
But you might want to try and use Eattext, the wizard makes it easy
never mind about Eattext, won't work in 2002 LT
  • 1 year later...
Hi Can Some One Lead Me In The Right Direction About Extracting Attributes
What I Need Is A Way To Take Attributes From One Block And Aplly Them To Another Blocks Defined Attributes My Example Is On A Wiring
Diagram There Is A Terminal Symbol That Lists: Terminal Number, Location And Then Wiremark
The Next Drawing Has Attributed 12 Position Standard Terminal Decks
The Key Is Trying To Get The Wire Marks Lined Up With The Right Terminal W/o A Lot Of Typing Which I Hate
