ASMI Posted November 18, 2008 Posted November 18, 2008 This routine can to number attributes one oby one http://www.asmitools.com/Files/Lisps/Renum.html. There is MNUM version with selection of numbering direction: (defun c:mnum(/ stStr stNum nLen cAtr dLst blName fLst blLst blSet aName sLst lZer aStr pt1 pt2 xSrt ySrt) (vl-load-com) (if (and (setq stStr(getstring "\nSpecify start number: ")) (setq stNum(atoi stStr)) (setq nLen(strlen stStr)) ); end and (progn (if (and (setq cAtr(nentsel "\nPick attribute > ")) (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr)))))) ); end and (if (and (setq pt1(getpoint "\nSpecify numbering direction ")) (setq pt2(getpoint pt1 "\nSpecify numbering direction ")) ); end and (progn (if(<=(car pt1)(car pt2))(setq xSrt '<)(setq xSrt '>)) (if(<=(cadr pt1)(cadr pt2))(setq ySrt '<)(setq ySrt '>)) (setq blName (vla-get-Name (vla-ObjectIDToObject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-OwnerID (vlax-ename->vla-object(car cAtr))))) fLst(list '(0 . "INSERT")(cons 2 blName)) aName(cdr(assoc 2 dLst)) ); end setq (princ "\n<<< Select blocks to number >>> ") (if (setq blSet(ssget fLst)) (progn (setq sLst (mapcar 'vlax-ename->vla-object (mapcar 'car (vl-sort (vl-sort (mapcar '(lambda(x)(list x (trans(cdr(assoc 10(entget x)))0 1))) (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet)))) '(lambda(a b)((eval xSrt)(caadr a)(caadr b)))) '(lambda(a b)((eval ySrt)(cadadr a)(cadadr b))))))) (foreach i sLst (setq lZer "") (repeat(- nLen(strlen(itoa stNum))) (setq lZer(strcat lZer "0")) ); end repeat (setq atLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes i)))) (foreach a atLst (if (= aName(vla-get-TagString a)) (vla-put-TextString a (strcat lZer(itoa stNum))) ); end if ); end foreach (setq stNum(1+ stNum)) ); end foreach ); end progn (princ "\nEmpty selection! Quit. ") ); end if ); end progn (princ "\nDirection not spaecified! Quit. ") ); end if (princ "\nThis isn't attribute! Quit. ") ); end if ); end progn (princ "\nInvalid start number! Quit. ") ); end if (princ) ); end of c:mnum Quote
Trebuchet Posted November 21, 2008 Posted November 21, 2008 This script worked great for me. Thank you so much. Saved me lots of time clicking, typing, and hitting escape. Quote
dusko Posted September 10, 2010 Posted September 10, 2010 love it (didn't know for this lsp)! thank you! Quote
TheyCallMeJohn Posted November 4, 2010 Posted November 4, 2010 ASMI, Is there a way to make a modification to so that you can put a prefix into it. i.e (PL-1000, PL-1001, & PL-1002). Second part is that occasionally I have to add blocks and I can't have the old blocks change there number but the new blocks denoted by "XXXX" need to be numbered sequentially from where the last block left off. I would appreciate help with one or both of these. If not the lisp you already wrote will save me lots of time! (Trying to learn lisp but its a slow process... tips and tutorials are always appreciated.) J PS: This block can select one portion of the block and not change the others right? (Haven't finished building the block for this yet!) Quote
The Buzzard Posted November 4, 2010 Posted November 4, 2010 ASMI,Is there a way to make a modification to so that you can put a prefix into it. i.e (PL-1000, PL-1001, & PL-1002). Second part is that occasionally I have to add blocks and I can't have the old blocks change there number but the new blocks denoted by "XXXX" need to be numbered sequentially from where the last block left off. I would appreciate help with one or both of these. If not the lisp you already wrote will save me lots of time! (Trying to learn lisp but its a slow process... tips and tutorials are always appreciated.) J PS: This block can select one portion of the block and not change the others right? (Haven't finished building the block for this yet!) This is an old thread and ASMI is no longer is involved in CAD to my recent knowledge. Quote
The Buzzard Posted November 4, 2010 Posted November 4, 2010 TheyCallMeJohn, Not to steer you away from this thread, But I made a program that does something similar to what you want to do. it is on this thread:http://www.cadtutor.net/forum/showthread.php?53207-Cable-Id-Number-Tag-Lisp Give it a look. Quote
TheyCallMeJohn Posted November 10, 2010 Posted November 10, 2010 Buzzard, Thanks for the advice and the recommendation but unfortunately that wont work for my application. But i have questions that you hopefully you will be able to help with... When I use the lisp above with blocks I have inserted using the "insert" command it works fine but when try and run it on blocks that I have copy and pasted or inserted within another block than exploded (i.e. so it then back to original block) the lisp does not detect the objects. I get the following response "Select objects: 0 found" I am attaching the lisp as I am using it. Once again any help would be appreciated. mnum.lsp Quote
The Buzzard Posted November 10, 2010 Posted November 10, 2010 TheyCallMeJohn, I wish I could answer that for you, But I do not work with Visual Lisp. You should start a new thread with your topic or problem. You will get more answers that way. Good Luck. Quote
Badwolf Posted October 28, 2011 Posted October 28, 2011 mnum is just what the doctor ordered! a request? I am using circles with 1 attribute value, they are being placed around a building perimeter and on a footing grid, sometimes turning angled directions it would be Awsome to choose them in a selection set or even one by one in order to be labeled then implement the command? maybe possible??? Quote
jva Posted May 7, 2012 Posted May 7, 2012 This routine can to number attributes one oby one http://www.asmitools.com/Files/Lisps/Renum.html. There is MNUM version with selection of numbering direction: (defun c:mnum(/ stStr stNum nLen cAtr dLst blName fLst blLst blSet aName sLst lZer aStr pt1 pt2 xSrt ySrt) (vl-load-com) (if (and (setq stStr(getstring "\nSpecify start number: ")) (setq stNum(atoi stStr)) (setq nLen(strlen stStr)) ); end and (progn (if (and (setq cAtr(nentsel "\nPick attribute > ")) (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr)))))) ); end and (if (and (setq pt1(getpoint "\nSpecify numbering direction ")) (setq pt2(getpoint pt1 "\nSpecify numbering direction ")) ); end and (progn (if(<=(car pt1)(car pt2))(setq xSrt '<)(setq xSrt '>)) (if(<=(cadr pt1)(cadr pt2))(setq ySrt '<)(setq ySrt '>)) (setq blName (vla-get-Name (vla-ObjectIDToObject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-OwnerID (vlax-ename->vla-object(car cAtr))))) fLst(list '(0 . "INSERT")(cons 2 blName)) aName(cdr(assoc 2 dLst)) ); end setq (princ "\n<<< Select blocks to number >>> ") (if (setq blSet(ssget fLst)) (progn (setq sLst (mapcar 'vlax-ename->vla-object (mapcar 'car (vl-sort (vl-sort (mapcar '(lambda(x)(list x (trans(cdr(assoc 10(entget x)))0 1))) (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet)))) '(lambda(a b)((eval xSrt)(caadr a)(caadr b)))) '(lambda(a b)((eval ySrt)(cadadr a)(cadadr b))))))) (foreach i sLst (setq lZer "") (repeat(- nLen(strlen(itoa stNum))) (setq lZer(strcat lZer "0")) ); end repeat (setq atLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes i)))) (foreach a atLst (if (= aName(vla-get-TagString a)) (vla-put-TextString a (strcat lZer(itoa stNum))) ); end if ); end foreach (setq stNum(1+ stNum)) ); end foreach ); end progn (princ "\nEmpty selection! Quit. ") ); end if ); end progn (princ "\nDirection not spaecified! Quit. ") ); end if (princ "\nThis isn't attribute! Quit. ") ); end if ); end progn (princ "\nInvalid start number! Quit. ") ); end if (princ) ); end of c:mnum Sorry for bringing up this ancient post, but I found out this extremely useful routine only now and I'm wondering if it could be modified to work with dynamic blocks also. Unfortunately I don't speak lisp (yet) so I don't have any clues where to start.. Quote
fixo Posted May 7, 2012 Posted May 7, 2012 I think best way without good book is here: www.afralisp.net where I've started from many years ago, btw... we need more detail about your task. The image or a copy of the drawing with this block would be interesting to see. Click on "Go Advanced" on lower right of reply box, then click on "Manage Attachments", browse to the file and select "Upload" and also show what is before and after ~'J'~ Quote
jva Posted May 7, 2012 Posted May 7, 2012 Thx for the reply and the link, I'll check it out. The problem is I have an array of dynamic blocks with a multiple visibility state and when using the code from my previous post the selection of blocks doesn't work. AutoCAD just says "Select objects: 0 found" when I click on a dynamic block. I've attached an example drawing. Code works with block EXAMPLE2, but not with EXAMPLE1. Example.dwg Quote
fixo Posted May 7, 2012 Posted May 7, 2012 Try this code, I've changed just three line in there (defun c:mnum(/ stStr stNum nLen cAtr dLst blName fLst blLst blSet aName sLst lZer aStr pt1 pt2 xSrt ySrt) (vl-load-com) (if (and (setq stStr(getstring "\nSpecify start number: ")) (setq stNum(atoi stStr)) (setq nLen(strlen stStr)) ); end and (progn (if (and (setq cAtr(nentsel "\nPick attribute > ")) (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr)))))) ); end and (if (and (setq pt1(getpoint "\nSpecify numbering direction start")) (setq pt2(getpoint pt1 "\nSpecify numbering direction end")) ); end and (progn (if(<=(car pt1)(car pt2))(setq xSrt '<)(setq xSrt '>)) (if(<=(cadr pt1)(cadr pt2))(setq ySrt '<)(setq ySrt '>)) (setq blName (vla-get-effectiveName ;<-- changed (vla-ObjectIDToObject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-OwnerID (vlax-ename->vla-object(car cAtr))))) ; fLst(list '(0 . "INSERT")(cons 2 blName)) fLst (list(cons 0 "INSERT")(cons 2 (strcat "`*U*,"blName)));<-- changed aName(cdr(assoc 2 dLst)) ); end setq (princ "\n<<< Select blocks to number >>> ") (if (setq blSet(ssget "F" (list pt1 pt2) fLst));<-- changed (progn (setq sLst (mapcar 'vlax-ename->vla-object (mapcar 'car (vl-sort (vl-sort (mapcar '(lambda(x)(list x (trans(cdr(assoc 10(entget x)))0 1))) (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet)))) '(lambda(a b)((eval xSrt)(caadr a)(caadr b)))) '(lambda(a b)((eval ySrt)(cadadr a)(cadadr b))))))) (foreach i sLst (setq lZer "") (repeat(- nLen(strlen(itoa stNum))) (setq lZer(strcat lZer "0")) ); end repeat (setq atLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes i)))) (foreach a atLst (if (= aName(vla-get-TagString a)) (vla-put-TextString a (strcat lZer(itoa stNum))) ); end if ); end foreach (setq stNum(1+ stNum)) ); end foreach ); end progn (princ "\nEmpty selection! Quit. ") ); end if ); end progn (princ "\nDirection not spaecified! Quit. ") ); end if (princ "\nThis isn't attribute! Quit. ") ); end if ); end progn (princ "\nInvalid start number! Quit. ") ); end if (princ) ); end of c:mnum Thanks to ASMI, it's a good job ~'J'~ Quote
jva Posted May 8, 2012 Posted May 8, 2012 I've one more question (read: modification job). Is it easy to change the code to support also text strings or letters? Like numbering A1.1, A1.2, A1.3 and so on.. Or A1, A2, A3 and so on.. Only the last number(s) would change. Quote
fixo Posted May 8, 2012 Posted May 8, 2012 (edited) Try this code ;;---------------------------------------- Code start ---------------------------------------;; ;; private function (defun inc-digit (st / alpha dig num prec) (setq alpha (vl-list->string (vl-remove-if-not '(lambda (a) (< 64 a 91)) (vl-string->list st)))) (setq num (vl-list->string (vl-remove-if '(lambda (a) (< 64 a 91)) (vl-string->list st)))) (if (vl-string-position (ascii ".") num) (progn (setq prec (- (strlen num) (1+ (vl-string-position (ascii ".") num)))) (setq dig (vl-princ-to-string (+ (atof num) (* 1 (expt 10. (- prec)))))) (if (< (strlen dig) (strlen num)) (setq dig (strcat dig "0"))) (setq alpha (strcat alpha dig))) (progn (setq prec (strlen num)) (setq dig (vl-princ-to-string (+ (atoi num) 1))) (setq alpha (strcat alpha dig)))) alpha ) ;;------------------------------ Main program ----------------------------;; ;; completely based on mnum.lsp by ASMI (defun c:anum(/ stStr stNum nLen cAtr dLst blName fLst blLst blSet aName sLst lZer aStr pt1 pt2 xSrt ySrt) (vl-load-com) (if (and (setq stStr(getstring "\nSpecify initial alpha-numeric value: ")) (setq stNum(atoi stStr)) (setq nLen(strlen stStr)) ); end and (progn (if (and (setq cAtr(nentsel "\nPick attribute > ")) (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr)))))) ); end and (if (and (setq pt1(getpoint "\nSpecify numbering direction start")) (setq pt2(getpoint pt1 "\nSpecify numbering direction end")) ); end and (progn (if(<=(car pt1)(car pt2))(setq xSrt '<)(setq xSrt '>)) (if(<=(cadr pt1)(cadr pt2))(setq ySrt '<)(setq ySrt '>)) (setq blName (vla-get-effectiveName ;<-- changed (vla-ObjectIDToObject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-OwnerID (vlax-ename->vla-object(car cAtr))))) fLst (list(cons 0 "INSERT")(cons 2 (strcat "`*U*,"blName)));<-- changed aName(cdr(assoc 2 dLst)) ); end setq (princ "\n<<< Select blocks to number >>> ") (if (setq blSet(ssget "F" (list pt1 pt2) fLst));<-- changed (progn (setq sLst (mapcar 'vlax-ename->vla-object (mapcar 'car (vl-sort (vl-sort (mapcar '(lambda(x)(list x (trans(cdr(assoc 10(entget x)))0 1))) (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet)))) '(lambda(a b)((eval xSrt)(caadr a)(caadr b)))) '(lambda(a b)((eval ySrt)(cadadr a)(cadadr b))))))) (foreach i sLst (setq atLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes i)))) (foreach a atLst (if (= aName(vla-get-TagString a)) (progn (vla-put-TextString a stStr ) (setq stStr(inc-digit stStr)) ) ); end if ); end foreach (setq stNum(1+ stNum)) ); end foreach ); end progn (princ "\nEmpty selection! Exit. ") ); end if ); end progn (princ "\nDirection not specified! Exit. ") ); end if (princ "\nThis isn't attribute! Exit. ") ); end if ); end progn (princ "\nInvalid start number! Exit. ") ); end if (princ) ); end of c:anum (princ "\nStart command with \"ANUM\"") (prin1) ;;---------------------------------------- End of code ---------------------------------------;; ~'J'~ Edited May 8, 2012 by fixo code added Quote
ANTIADDICT Posted July 26, 2013 Posted July 26, 2013 Find line: (setq stNum(1+ stNum)) and change to (setq stNum(+ 2 stNum)) how could I change the code to prompt me to ask what I would like the increments to be, similar to how 'tcount' asks, rather than change the code each time I want to change the increments? Thank you. Quote
Artek Posted August 30, 2013 Posted August 30, 2013 1. Specify start number2. Pick to wanted attribute 3. Select blocks and press Spacebar Enjoy... (defun c:mnum(/ stStr stNum nLen cAtr dLst blName fLst blLst blSet aName sLst lZer aStr) (vl-load-com) (if (and (setq stStr(getstring "\nSpecify start number: ")) (setq stNum(atoi stStr)) (setq nLen(strlen stStr)) ); end and (progn (if (and (setq cAtr(nentsel "\nPick attribute > ")) (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr)))))) ); end and (progn (setq blName (vla-get-Name (vla-ObjectIDToObject (vla-get-ActiveDocument (vlax-get-acad-object)) (vla-get-OwnerID (vlax-ename->vla-object(car cAtr))))) fLst(list '(0 . "INSERT")(cons 2 blName)) aName(cdr(assoc 2 dLst)) ); end setq (princ "\n<<< Select blocks to number >>> ") (if (setq blSet(ssget fLst)) (progn (setq sLst (mapcar 'vlax-ename->vla-object (mapcar 'car (vl-sort (vl-sort (mapcar '(lambda(x)(list x(cdr(assoc 10(entget x))))) (vl-remove-if 'listp (mapcar 'cadr(ssnamex blSet)))) '(lambda(a b)(<(caadr a)(caadr b)))) '(lambda(a b)(>(cadadr a)(cadadr b))))))) (foreach i sLst (setq lZer "") (repeat(- nLen(strlen(itoa stNum))) (setq lZer(strcat lZer "0")) ); end repeat (setq atLst (vlax-safearray->list (vlax-variant-value (vla-GetAttributes i)))) (foreach a atLst (if (= aName(vla-get-TagString a)) (vla-put-TextString a (strcat lZer(itoa stNum))) ); end if ); end foreach (setq stNum(1+ stNum)) ); end foreach ); end progn (princ "\nEmpty selection! Quit. ") ); end if ); end progn (princ "\nThis isn't attribute! Quit. ") ); end if ); end progn (princ "\nInvalid start number! Quit. ") ); end if (princ) ); end of c:mnum Hi ASMI, Any chance of tweaking your brilliant code to work on a fixed attribute/tag name instead selecting one? Thanks. Quote
Suraj Bhunje Posted August 30, 2013 Posted August 30, 2013 Hi! ASMI.. Tht was really a great code u provided here. It worked just like a butter-spread in first attempt. But it only allows the program to update numbers of Attributes in +ve X-Axis direction, irrespective of how you select the Attributes. Can you suggest a modification for numbering of the Attributes I selected in the sequence of their selection instead of X-Axis direction please?? Quote
