Joan_Ray Posted May 11, 2009 Posted May 11, 2009 Hello Frnds, Some months before i knew this but..... I was in paper space and after zooming in much I worked in model tab. Now I want to get back to paperspace. But the viewport boundary is not visible. If I try to zoom in & out it zooms into the model because the viewport is not locked. Someone can help me out of this. Thanks JOAN Quote
tkelly Posted May 11, 2009 Posted May 11, 2009 Hi, Just type vpmax commandyou will get a red boundary near the working (black) screen. double click outside this red boundary. Now you are back in the paper space. Hope i helped you. Enjoy Tom Kelly Quote
Dipali Posted May 11, 2009 Posted May 11, 2009 Hello Frnds,Some months before i knew this but..... I was in paper space and after zooming in much I worked in model tab. Now I want to get back to paperspace. But the viewport boundary is not visible. If I try to zoom in & out it zooms into the model because the viewport is not locked. Someone can help me out of this. Thanks JOAN Just type 'ps' at the commnad line. but because the viewport was not locked, it will not retain its previous saved view. next time you want to work in modle space, thru paper sapce, use 'vp max' s suggested by tkelly. you can simply double click the boundry of vp to use that feature & to come back again use 'ps' this will keep your last saved view in model space intact. Quote
