Fire Alarm Posted May 11, 2009 Posted May 11, 2009 I'm still figuring out how to use parameters and am wonder if it is possible to have multiple blocks for a parameter. I created a block parameter with smoke, heat, and duct detectors. My question is this: when I go to change the parameter to a certain device and then use bcount it does not recognize the block. Is there a way of doing this so that each parameter is counted? For example if I have 25 smoke detectors, 15 heats, and 10 duct detectors (total 50 devices). Is there a way to break these out as to how many of each device there is? I attached an example of the file. Thanks, Andrew DETECTORS.dwg Quote
luther4000 Posted June 24, 2009 Posted June 24, 2009 I don't know about MEP, but AutoCAD Architecture has the "Select Similar" option. With that if you select one of the blocks, right click and SELECT SIMILAR it will select only the blocks with the same visibility parameter active. If you have the properties palette open, then you will see on the Top box showing the selection "Block Reference (NN)" being NN the number of blocks selected. that should do the trick. If MEP doesn't have the SELECT SIMILAR option, this thread explains how to add it Hope this helps Quote
Fire Alarm Posted June 24, 2009 Author Posted June 24, 2009 Thank you luther4000. I will give this a try and let you know how it works. Quote
Garrett12 Posted November 4, 2009 Posted November 4, 2009 Fire alarm system is a system to maintaining an atmosphere on either side of the door during evacuation and fire fighting efforts.For more information log on: amlarm.com Quote
