In 2008 my Express tools are installed put they all have a question mark at the side to say they are missing.
I typed in MENULOAD but cant find anything, what could be wrong?
  • Replies 31
  • happyunited
    11
  • SLW210
    4
  • Ritch7
    4
  • NBC
    2
I also went to check a friends computer and it UNLOAD by mistake, **** please help!!
Usually typing EXPRESSTOOLS in the commandline will install it for you.
Is the EXPRESS folder in acad's support path?
You could also try EXPRESSMENU at the command line :)
thanks. that worked for me but not my friends!
what could be wrong
worked for me but not for him!
what version has ur m8 got? it should work for all mainly
Never mind
thats true I dont really care but if it was something easy it would be handy.
he has 2008 too
lol ah i just catched what you put, did u just type the exact same scenetence about the express menu as hedge?:?
he has 2008 too
What is missing? The Menu and/or the Toolbars. AutoCAD will only display 24 Menus. Do the commands work on the commandline? Those two commands should have done it. You may have to reinstall them from the disk.
what could be wrong
He's not your friend, perhaps ?!
Just blow a raspberry at him, and laugh.
happy im a fellow united fan il try to help you out, so are you saying ur freind has the exact same version as you but when he types it in the command line he dosent get the menu up? .. weird:?
Yea, just a little late.
yes.
if he types TXT2TEXT it doesnt work. the menu bars are showing but they have question marks next to them on the express drop down menu. So the express menu is there only non of the commands work.
yes.
Try TXT2MTXT
Try TXT2MTXT
sorry thats what he does type, non of them work that was just one example he used.
Guest LElkins
I assume from your first post that he did have the express tools, but doesn't anymore? so that removes the possibility of them not being installed....
If you type CUI, is it listed in the 'Partial CUI Files'?
Cheers
Is there something like...
C:\Program Files\Autodesk Building Systems 2007\Express
... in the support search file path?
