Andy 100 Posted May 12, 2009 Posted May 12, 2009 Can anyone help? I'm using autocad 2009 and I had a properties tool bar to the side of my screen that has gone missing. If I go into the menu and click on properties nothing happens. Thanks. Quote
stevsmith Posted May 12, 2009 Posted May 12, 2009 have you tried reloading the workspace? switch it over to 3d then back to 2d Quote
The Buzzard Posted May 12, 2009 Posted May 12, 2009 Type _properties at the command prompt see what happens. Quote
stevsmith Posted May 12, 2009 Posted May 12, 2009 hang on! Do you have any locks on, eg windows, toolbars etc. if not you may have dragged the proporties panel under another ribbon panel. I hope this makes sense Quote
Andy 100 Posted May 12, 2009 Author Posted May 12, 2009 Nothing happens if I type properites and the command line. The tool bar was a large bar it had loads of bits on it so if I wanted to change text size, colour or change any part of the drawing I just used that. Quote
The Buzzard Posted May 12, 2009 Posted May 12, 2009 As Steve mentioned, It could be behind something. I see no reason for it to not respond to the command on the prompt. Quote
Andy 100 Posted May 12, 2009 Author Posted May 12, 2009 Thanks guys I will try and upload the tool bar thing from my laptop so you can see what i'm missing. Quote
Car5858 Posted May 27, 2009 Posted May 27, 2009 Thanks guys I will try and upload the tool bar thing from my laptop so you can see what i'm missing. I have also had this problem. It resulted in the properites window being streched and the auto hide feature enabled. I ended up repairing the installation at the Add/Remove programs options of my XP system. Once the program was restored to system defaults I opened the properties dialog box and docked it on the left side of the screen. I have not had another problem with it so far. Carl Quote
