Could some one please tell me how to get rid of the unwanted lines in my drawing.The drawing is a frame work out of purlins.Thankyou
purlins frame.dwg
Weird. I see them when zoomed all the way out but as I begin to zoom in they start to disappear. Do they plot?
All the lines plot.Dispsilh is on 0.Thanks fo looking
All? Even the unwanted lines?
Try running an AUDIT on the drawing.
If you were to recreate the geometry do the lines still show up?
Tried audit with no luck so redrew.Unwanted lines still show and plot when on 3d visual hidden style and conceptual visual style. Thanks
I been looking at this, and it seems strange that when you scroll in the lines not only disappear but the whole view scrolls behind the view point, as if the view point is zooming out and not zooming in on the image as normal, is this normal when using 3d (I dont use it btw), also if you check out layout 2 its has no extra lines
Since it is a 3D drawing and seems like a 3D problem, Maybe you should have your post moved to a 3D forum. I believe you can get your answer there.
