I teach an Autocad cad and a student's 3D model will not hide polygons using Visual Styles/Conception in Autocad 2008. I have reviewed other projects on the same computer and this issue only occurs on two files. Is there a setting that causes this to occur saved locally inside the CAD file?
Much thanks for any help
Check in the "visual styles manager" for conceptual.
If "Fast Silhouette Edges" is YES then try lowering the number to 1. or turning it off altogether.
Check the "EDGE SETTINGS" also. This may help.
KC
I tried both of your suggestions, but no luck. I have attached the file if you are interested in taking a look. The only thing I can think of is that it has something to do with her working on a Mac with Windows installed (never a good idea). In addition to the polygons, the faces are strangely rendered and the model shakes when using orbit. I ran a recover but nothing changed. Thanks for you help.
3DCabin_SZ.dwg
