Now, I'm trying it on the real model, not on the illustration, and I'm having trouble selecting the objects. Is it possible that it's due to the fact that the different objects (base vector, circle, curve) are drawn in different layers? Should these layers be merged in one or maybe the script can be made to select objects independent of what layer they're drawn on?
  • Replies 231
  • Lee Mac
    107
  • lizp
    99
  • SEANT
    24
  • The Buzzard
    2
Posted Images
Thanks for your kind words :)
It shouldn't matter which layer the objects are drawn on, just the type of objects they are - what objects are you having trouble selecting?
Here's an example of the actual file (see attached).
When I run your code it asks me to select a circle and I do that (either or the inner circle), then it asks me to select the base vector but when I select it it just just brings me back to the Command: The goal is to select that base vector and then select the point on the curve where base vector is applied ahnd have it decomposed accordingly. That happens on the illustration I gave ut not on the actual drawing.
Sorry, the dxf file I thought I've attached exceeds the forum limits. Will have to see how to compress it.
Try this:
(defun c:vec  (/ doc spc Circ cCen lObj lAng lLen grdat cEnt pt tan tanpt norpt ptlst)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (if (and (setq Circ (car (entsel "\nSelect Circle: ")))
          (eq "CIRCLE" (cdadr (entget Circ)))
          (setq bVec (car (entsel "\nSelect Base Vector: ")))
          (member (cdadr (entget bVec))
                    '("LINE" "LWPOLYLINE" "POLYLINE")))
     (setq cCen (cdr (assoc 10 (entget Circ)))
           lObj (vlax-ename->vla-object bVec)
           lAng (angle '(0 0 0)
                       (vlax-curve-getFirstDeriv bVec
                         (vlax-curve-getStartParam bVec)))
           lLen (vla-get-Length lObj))
     (princ "\nSelect Curve: ")
     (while (eq 5 (car (setq grdat (grread t 5 2))))
       (if (and (setq cEnt (car (nentselp (cadr grdat))))
                (member (cdadr (entget cEnt))
                        '("LWPOLYLINE" "POLYLINE" "CIRCLE" "ELLIPSE" "ARC" "LINE" "SPLINE"))
                (not (eq Circ cEnt)))
         (redraw cEnt 3)
         (mapcar '(lambda (x) (redraw x 4))
                 (mapcar 'cadr
                         (ssnamex (ssget "_X"))))))
     (if cEnt
         (while (eq 5 (car (setq grdat (grread t 5 0))))
           (redraw)
           (setq cObj   (vlax-ename->vla-object cEnt)
                 pt     (vlax-curve-getClosestPointto cObj (cadr grdat))
                 tan    (vlax-curve-getFirstDeriv cObj
                          (vlax-curve-getParamatPoint cObj pt))
                 angdif (abs (- (angle '(0 0 0) tan) lAng))
                 tandif (abs (- (angle '(0 0 0) tan) (angle pt cCen)))
                 tanpt  (polar pt (angle '(0 0 0) tan) (* lLen (cos angdif)))
                 radtan (polar pt (angle pt cCen) (* (distance pt tanpt) (cos tandif)))
                 pertan (polar pt (+ (angle pt cCen) (/ pi 2)) (* (distance pt tanpt) (sin tandif)))
                 norpt  (polar pt (+ (/ pi 2) (angle '(0 0 0) tan)) (* lLen (sin angdif)))
                 bsvpt  (polar pt lAng lLen))
           (grvecs (list 3 pt tanpt 3 pt norpt 8 pt cCen 1 pt bsvpt 4 pt radtan 4 pt pertan)))
         (if (eq 3 (car grdat))
             (setq ptlst (mapcar 'vlax-3d-point (list pt tanpt norpt cCen radtan pertan bsvpt)))
             (vla-put-color (vla-addline spc (car ptlst) (cadr ptlst)) acGreen)
             (vla-put-color (vla-addline spc (car ptlst) (caddr ptlst)) acGreen)
             (vla-put-color (vla-addline spc (car ptlst) (cadddr ptlst))
             (vla-put-color (vla-addline spc (car ptlst) (nth 4 ptlst)) acCyan)
             (vla-put-color (vla-addline spc (car ptlst) (nth 5 ptlst)) acCyan)
             (vla-put-color (vla-addline spc (car ptlst) (last ptlst)) acRed))))))
   (princ "\n<!> No Circle Selected <!>"))
 (command "_regenall")
 (princ))
If the objects are Blocks - this routine will not work - they will need to be Curve Objects (Polylines, Arcs, Ellipses, Circles, etc etc) for this to function. :wink:
PS> Nice wheel!
PS> Nice wheel!
Oh, I see. Can these be unblocked or a completely new wheel has to be drawn?
Your last code works perfectly on the illustration. Can now the product of the length of the radial line and the component perpendicular to the radial line appear somewhere on the screen and possibly be imported into an Excel sheet? That would be the ultimate. Wonder if it's possible at all. See, the thing is all eight torques, calculated individually by your code, are to be summed up in the end to get the net torque.
Well, the objects could be exploded into their individual components, using the EXPLODE command I suppose.
Ok give this a shot, it will write the info to a CSV file of the same name as the drawing file :)
(defun c:vec  (/ doc spc Circ bVec path cCen lObj lAng lLen
                grdat cEnt ofile pt tan angdif tandif
                radtan pertan tanpt norpt ptlst)
 (vl-load-com)
     (setq path (strcat (getvar "DWGPREFIX")
                        (substr (getvar "DWGNAME") 1
                                (- (strlen (getvar "DWGNAME")) 4)) ".csv")
         (redraw cEnt 3)
                 (mapcar 'cadr
     (if cEnt
         (setq ofile (open path "a"))
           (redraw)
             (setq torq (* (distance pt cCen) (distance pt pertan)))
             (princ (strcat "\n<< Calculated Torque: " (rtos torq) " >>\n"))
             (write-line (rtos torq 2  ofile)
             (close ofile))))))
 (princ))
. . . . See, the thing is all eight torques, calculated individually by your code, are to be summed up in the end to get the net torque.
I'd hazard the guess that the Sum of all the torques will be zero. Can’t have something breaking the Second Law of Thermodynamics, now can we. o:)
@SEANT, I'd love to discuss this with you and with anyone who'd be willing to but let's settle first on the tool. Wonder if this forum would be the best place to carry out such discussion?
Good Point. And, the likely outcome of this particular thread is good CAD. That's the name of the game at this forum.
Sorry, can't find where the CSV file is saved. Also, can't the value be displayed somewhere on the screen?
Indeed. It's unbelievable what Lee is doing. A rare individual.
I notice the csv is saved to where the drawing file is.
Yeah, I'm trying to find it there, to no avail, though.
I got it. All set. I've probably worked with the older version of vec.lsp thinking it's the new one. Would be nice to have the value on the screen too.
The value is printed to the command line when the function completes :)
This is indeed correct, - it is saved in the same place as where the drawing is saved, under the same name as the drawing.
