dose autocad have ability like 3dsmax that could show rendere boundry in viewport?
What would be the purpose behind such a function? What are you trying to accomplish?
Safe Frames are like the little dashed line in paper space that defines your actual printable area, except the safe frames define your renderable area. I could be wrong, but I don't think Autocad has this feature, unless they've added it recently? :unsure:
Safe Frames are mostly used when doing animation though, so I don't think they would really be of much use in Autocad.
Thank you Cad64 for educating me on safe-frames. Much appreciated.
tnx cad 64 for ur reply.
you are right about this type of featuer in autocad.my goal was compositing a 3d space in 2d bitmap pictuer.for instance in 3dsmax you can put pictuer in background and in your redner output.but as i saw in autocad pictuers in background couldnt zoom or paned ???!!and whenever i justifid semi matched prepective mentalray output is is something else...any way tnx
