Everything that i fillet while modeling, after i save the file and exit next time i open it everything that fillet becomes square again.
Is there a way that i can stop this from happening cause it really gets on your nerve everytime doing the same thing.
try a REGENALL :)
No success. Anything else? please help.
are you sure the angles are 90degrees straight? Can you post the file here? Maybe i sort it out for you.
Z
are we talking Lines and Polylines here or 3D-solids?
how about changing the setting of your VIEWRES variable?
Turn off solidhist before beginning. Attach the file here and I might be able to fix it for you.
I'm talking about 3d solids, i fillet the edges and after saving and exiting the next i open them they become square again. I can't upload the file it's to big.
There were something like 35 parts in this file - some with fillets and some without. Can you isolate a just a single part that the fillets are now missing?
Those who are on the kitchen are with fillets but the next time i open the file the fillets are gone, i guess UNION command has something to do with it, and those who are not on the kitchen are all separated solids(some with fillets also). So i don't understand why do the fillets lose after i exit the file?
So all the kitchen doors are used with fillets but now the filleting is gone.
OK, since no one found the solution for this, i solved my own problem:D
The problem was that it was set to save the file in autocad2000 file, so i guess this is a version that doesnt have filleting or whatever, the thing is that i changed the settings and now it's ok. So if someone else has this problem now they can solved it by reading this.
