Tallie Posted May 20, 2009 Share Posted May 20, 2009 Hi all, I have an ECW I need for the background of a drawing. When I attatch it, it doesn't come in at any coordinates, it's inserted at 0,0 (which is obviously wrong). So I was wondering if anyone out there could help me out. Is it possible to solve this problem with AutoCAD or will I need AutoCAD Map or even something else? Cheers Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 23, 2009 Share Posted May 23, 2009 And what exactly is an ECW? Quote Link to comment Share on other sites More sharing options...
feargt Posted May 24, 2009 Share Posted May 24, 2009 How are you inserting it? just through Insert command or are you using the insert option under the Map menu? You will have to use the insert under the Map menu for Autocad to read the coordinates. CAD64, ECW file is a compressed image, that is much smaller than a tif image Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 24, 2009 Share Posted May 24, 2009 Thanks for the clarification. FYI: Autocad doesn't have a "Map" menu. That's a Civil 3D thing. Quote Link to comment Share on other sites More sharing options...
Tallie Posted May 25, 2009 Author Share Posted May 25, 2009 I don't currently have civil 3D or map. (but map is available to me on one computer). I have been attatching it to the drawing, as an xref - just an image instead of a drawing. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 26, 2009 Share Posted May 26, 2009 And what exactly is an ECW? According to Google.com Energy Center of Wisconsin: Accelerating Energy Efficiency Quote Link to comment Share on other sites More sharing options...
Tallie Posted November 24, 2009 Author Share Posted November 24, 2009 Hi all, This is just a follow up as I have finally had the time and worked out my problem. So I thought I should post my solution in case any one ever has the same problem as me. To insert ECWs into the correct coordinates: 1. In AutoCAD Map go Create -> Insert an Image. Select the desired Image. It's best to insert the ECW this way, opposed to data connection as this way the image is inserted as a raster image which autocad can read and wont crash. 2. Save as DWG Hope This Helps anyone Quote Link to comment Share on other sites More sharing options...
Kausar Posted September 1, 2020 Share Posted September 1, 2020 Hi All.I have a ecw file. I want insert ecw file in autocad LT 2021. Is it possible to help me, How to import ? Quote Link to comment Share on other sites More sharing options...
Kausar Posted September 1, 2020 Share Posted September 1, 2020 OK. I am waiting , until you reply. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 1, 2020 Share Posted September 1, 2020 When inserting images with real world they often have a second file as an example a JPG file may have the following JGW which contains the image details, the values could be read in say excel and insert and scale worked out. ;;;Reads world tiff file (.jgw) to scale and place image correctly in autocad. ;;;First insert all tiff images into drawing at whatever scale and insertion point. ;;;If the jgw exists in same directory and is named the same as the image selected, ;;;it will automatically be found and the image will be scaled and placed. If it is ;;;not in the same directory, the user can browse for the file. ;;;03.23.2011 Added support to create jgw files as well as support rotated images ;;;Needs a file with 6 lines (ScaleX Rotation -Rotation -ScaleY TopLeftXCoord TopLeftYCoord) ; « Last Edit: April 12, 2011, 09:43:43 am by ronjonp » The only other way is insert near correct and if LT has "Align" can realign image. There are programs out there that can read the values that are in side maybe a ecw file and then use excel. Quote Link to comment Share on other sites More sharing options...
