happyunited Posted May 20, 2009 Posted May 20, 2009 Hi I have a drawing which I am trying to paste in a few objects (text/blocks etc) but when I copy from another drawing and attempt to past I get the following error message when trying to paste in some MTEXT; Command: _pasteclip Specify insertion point: ** Undefined block #-1 I don't have this problem with any other drawing and I have even copyied the contents of this problem drawing to another blank drawing but still the same problem. Anyone got any ideas? Thanks in advance. Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 Found this at the AutoDesk Discussion Groups. Maybe it will help define the problem for you and solve it too. http://discussion.autodesk.com/forums/message.jspa?messageID=4631969 Quote
happyunited Posted May 20, 2009 Author Posted May 20, 2009 Found this at the AutoDesk Discussion Groups. Maybe it will help define the problem for you and solve it too. http://discussion.autodesk.com/forums/message.jspa?messageID=4631969 Thanks for that, i'll give it a read Quote
ReMark Posted May 20, 2009 Posted May 20, 2009 And please let us know if you get the problem solved. Thank you. Quote
