venuj99 Posted May 22, 2009 Posted May 22, 2009 hi Need some help regarding annotation scales, if i have several scale on one drawing in one viewport. is there an easier way to delete the unused scale inside the viewport? Quote
GE13579 Posted May 22, 2009 Posted May 22, 2009 I'm confused as to why you would have more than one scale in a given viewport? Can you be a little more clear? Quote
venuj99 Posted May 22, 2009 Author Posted May 22, 2009 yer sorry, my problem is that lets say the drawing was innitially in 1:10 viewport with the annotation scale for text was at 1:10. and then let say i change it to 1:20 viewport and the annotation scale at 1:20. so now i had both 1:10 and 1:20 on the text, but i only want to have the 1:20 scale, so the normal method i have been using is that select everything and delete the not active scale in this instance 1:10. but i was wondering if there is an easier way of doing this like a command or button in autocad 2008 where you just say to delete the scale annotation aboject which are not in use. so i was wondering if anyone knew how to do this? thanks, Quote
