Jamie Bass Posted February 27, 2008 Posted February 27, 2008 Using AutoCAD2008LT, recently upgraded: When binding an xref to a subordinate drawing, the bound drawing completely disappears. How can I sort this problem out, and in particular, how can I retain the layers that are showing in "model space in paper space" without having to reset all the layer properties? I read somewhere that I need to purge the layers but this does not resolve the problem anyway This never used to happen in 2000 or 2004, seems to be a new occurrence for 2008? All help gratefully received! Quote
Dipali Posted February 28, 2008 Posted February 28, 2008 Post your drawing here & i will try it on my system to see why it is happening. Quote
Chudwick Posted April 29, 2009 Posted April 29, 2009 Having this issue today also in 2008, has anyone figured out what is causing the xrefs to disappear? Quote
IheartCAD Posted August 26, 2009 Posted August 26, 2009 I have been having this problem too. I find that when I go into the xrefed file and do a purge, audit, save then refresh the xref it will bind/insert after that. Quote
LearningQuickly Posted September 1, 2009 Posted September 1, 2009 I am having the same issue in Civil3D 2010. Usually purging and auditing both the xref and drawing fixes the problem for me. If that doesnt work try just detaching the xref and re-attaching it. Though this has not been the case for me recently. I still cant figure it out.... Quote
