Civil3d as cad
Hi,
I made an deployment of Civil 3d 2010 32bit a few weeks back and now it seems it doesn't have an "Civil 3d as cad" shortcut installed with it.
When i try to modify the deployment there is no pickbox to enable that shortcut, this pickbox does show when i modify the 64bit deployment i also installed.
I can't find anything on google, but is there an way to create your own shortcut? And if so, how?
Thanks in advance.
In the bottom right corner of the screen (C3D 2009) near there is a gear wheel icon. Click that and you can switch to Classic (e.g. AutoCAD for 3D modelling) or a few other work spaces. If you use the C3D interface enough then you get used to finding your way around anyway.
I didnt get the icon for cad either.... go to start>all programs> autodesk> autocad civil 3d 2010> autocad civil 3d 2010 as cad.
Its in that list but it didnt creat an icon, if you right click on it you can send it to the desktop as a shortcut.
