Hey guys, im sad to tell you that my lisp development has slowed to an almost complete stop. Im juggling work and a few websites right now so im not getting even the time to read on the toilet :cry:
Just wondering, is it possible to create a lisp or several lisp files that will change the colours of objects by simply entering an alias for the colour lets say. Just a thought, thou with my very limited knowledge im not even sure where to start :oops:
Any help would be appreciated, as always :wink:
Z
Not sure if this helps but we had a txt file that contains all the layer parameters but are associated with a lisp variable so running your change lisp would read the text file first this means your lisp is not hardcoded with an answer nor do you have to enter a colour every time.
1234567890123456789012345678901234567890
Newname Programname Col LineType
brick--1 brick--1 1 continuous
ceiling--2 ceiling--2 6 continuous
ceiling--3 ceiling--3 6 continuous
ceiling--5 ceiling--5 6 continuous
script generated
(setq brick--1 "brick--1")
(setq brick--1col 1)
(setq brick--1lin "continuous")
(setq ceiling--2 "ceiling--2")
(setq ceiling--2col 6)
(setq ceiling--2lin "continuous")
I guess its helpfull if you want to alter a lot of drawings and set the standards. just check if variable exists if not manual answer.
