This is actually a followup to another post but it's different enough
I didn't want to stick inside the thread.
http://www.cadtutor.net/forum/showthread.php?t=36371
My objective is this:
Select a bunch of text and have the routine explode all the MTEXT
entities inside the SS (this is working - see code below)...
BUT I want to end up with a selection set with all of the originally
selected TEXT entities and the new TEXT entities that were created
from the exploded MTEXT entities.
(i don't want everything in the drawing, I want to pick..)
I have a feeling I need to use SSADD but I don't know how
to incorporate that into my code.
Here's what I have so far..
(defun c:XM4 ( )
(setvar "qaflags" 1) ;Thanks to the member who shared this!!
(setq t (ssget))
(setq mtss (ssget "P" '((0 . "MTEXT"))))
(if mtss
(command "explode" mtss "")
(princ))
Thanks so much!
I've learned so much from you guys!
Give this a shot:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:xm4 [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss mss [color=black]lstent[/color][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"QAFLAGS"[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] mss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_P"[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lstent [b][color=RED]([/color][/b][b][color=BLUE]entlast[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b] [b][color=#ff00ff]"_.explode"[/color][/b] mss [b][color=#ff00ff]""[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]ssadd[/color][/b] x ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b]ExEnts [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lstent lstent [b][color=RED]([/color][/b][b][color=BLUE]entlast[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]sssetfirst[/color][/b] [b][color=BLUE]nil[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> Nothing Selected <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] ExEnts [b][color=RED]([/color][/b]ent [b][color=BLUE]/[/color][/b] ent[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]entnext[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] ent [b][color=RED]([/color][/b]ExEnts ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Definitely a lisp diety!
Would you mind commenting on your code
for my further instruction?
thanks
Appreciate the help so much too!!
Hopefully this will help you :D
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:xm4 [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss mss lstent[b][color=RED])[/color][/b]
 [i][color=#990099]; Define Function and Localise Variables[/color][/i]
 [i][color=#990099]; Set QAFLAGS to 1 so that our Selection Set can be exploded[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b]  [i][color=#990099]; If the following is true...[/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [i][color=#990099]; All statements must return T[/color][/i]
     [i][color=#990099]; Get user to select Objects, filter for TEXT & MTEXT[/color][/i]
     [i][color=#990099]; Filter the previous set for just MTEXT[/color][/i]
   [b][color=RED])[/color][/b] [i][color=#990099]; end and[/color][/i]
   [i][color=#990099];| As a side note, both selection sets must[/i]
      [i]exist, allowing for the case in which the
      user only selects DTEXT, hence making mss nil.
   |[/i][/color][i][color=#990099];    [/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]  [i][color=#990099]; Wrap the following Statements:[/color][/i]
     [i][color=#990099]; Collect the last entity created[/color][/i]
     [i][color=#990099]; i.e. the last entity in the database[/color][/i]
     [i][color=#990099]; Explode the Selection Set[/color][/i]
       [i][color=#990099]; Apply the following function to every member of the list[/color][/i]
       [i][color=#990099]; Add each member of the following list to the selection set.[/color][/i]
       [b][color=RED]([/color][/b]ExEnts [i][color=#990099]; Call our sub-function using the argument:[/color][/i]
         [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lstent [i][color=#990099]; If an entity is in the database (before Explosion)[/color][/i]
           lstent [i][color=#990099]; Use it[/color][/i]
           [b][color=RED]([/color][/b][b][color=BLUE]entlast[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Else use the last entity created.[/color][/i]
           [b][color=RED])[/color][/b] [i][color=#990099]; end if[/color][/i]
         [b][color=RED])[/color][/b] [i][color=#990099]; end ExEnts[/color][/i]
       [b][color=RED])[/color][/b] [i][color=#990099]; end mapcar[/color][/i]
     [i][color=#990099]; Select the Selection Set[/color][/i]
     [b][color=RED])[/color][/b] [i][color=#990099]; End the "progn" wrap[/color][/i]
   [i][color=#990099]; Else no MTEXT or Nothing was Selected[/color][/i]
   [b][color=RED])[/color][/b] [i][color=#990099]; End if[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Exit Cleanly[/color][/i]
 [b][color=RED])[/color][/b] [i][color=#990099]; End Function[/color][/i]
[i][color=#990099]; -----------------------------------[/color][/i]
[i][color=#990099];Sub-Funtion:[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] [i][color=#990099]; Reverse the Following Result[/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [i][color=#990099]; If the following[/color][/i]
     [i][color=#990099]; If there is another entity in the database..[/color][/i]
     [i][color=#990099]; Add it to the list, and repeat the process[/color][/i]
   [b][color=RED])[/color][/b] [i][color=#990099]; end reverse[/color][/i]
When I grow up I want to code just like you!! (^_^)
Thanks so much!!
Not a problem :D
If you still have questions, just shout :D
