goldy2000 Posted May 28, 2009 Posted May 28, 2009 Hello everyone!!! I search for lisp that sorts coordinates in autocad drawing (X or Y) from min to max (or in the other way) and give numbers to that coordinates, so later it can be picked up to a text file...problem is that I was measuring huge pipeline couple of days with different point numbers, so now need to be in one line like I was doing it continuesly...Anybody know how to do it??? exceedingly grateful... Quote
ReMark Posted May 28, 2009 Posted May 28, 2009 Some sources for Lisp routines are listed here: http://www.cadtutor.net/forum/showthread.php?t=36178 Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 When you say "sorts Coordinates" are you talking about ACAD points? Quote
VVA Posted May 28, 2009 Posted May 28, 2009 Not clearly what co-ordinates need to be sorted (TEXT, POINT, POLYLINE). You could not publish a small example of that it is necessary to make (dwg) Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 First thx ReMark for link... Yep, I think about ACAD points (X,Y,Z) already put in their real coordinate system Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 I mean to sort POINT from min to max; but one of X or Y should be depend of numbering (example:X,Y,Z, name point 10,11,12 B point 12,13,12 A point 13,13,12 C point) There are 3 points with 3 coordinates, so need to renumber them in X axis and give them new point number, so B becomes A, A becomes B and C becomes C...and that so on...hope I helped??? Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 Perhaps something like this? [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ptSort [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss file tmp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] sort:def [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"POINT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] file [b][color=RED]([/color][/b][b][color=BLUE]getfiled[/color][/b] [b][color=#ff00ff]"Select File to Write"[/color][/b] [b][color=#ff00ff]""[/color][/b] [b][color=#ff00ff]"txt"[/color][/b] [b][color=#009900]9[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cnt [b][color=#009999]1.[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"X Y"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tmp [b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Coord to Sort by [X/Y] <"[/color][/b] sort:def [b][color=#ff00ff]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] tmp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sort:def tmp[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] file [b][color=RED]([/color][/b][b][color=BLUE]open[/color][/b] file [b][color=#ff00ff]"w"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]vl-sort[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x1 x2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b] car cadr[b][color=RED])[/color][/b] x1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b] car cadr[b][color=RED])[/color][/b] x2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]Make_Text pt [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cnt [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]write-line[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cnt [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#ff00ff]" --> "[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-princ-to-string[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b] file[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cnt [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] cnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]close[/color][/b] file[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Make_Text [b][color=RED]([/color][/b]pt val rot[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CLAYER"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]62[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] pt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSIZE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] val[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]50[/color][/b] rot[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]7[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSTYLE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]71[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]72[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]73[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]11[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 Problem is that I have a lot of points that have completely different numbers and I need to renumber them, good thing is that pipeline goes in one direction in X-axis so it would help me to find lisp that sorts POINTs in X axis and which would renumber them and put them in some new layer, if it is possible...as I am completelly new in LISP programming.. Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 Yep Lee MAc that is good, veeery good!!! I was searching that...Is there an option to put new renumbered points in some new layer??? Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 And I saw that export txt file looks like that: 1 --> (6.47481e+006 5.00382e+006 0.0) 2 --> (6.47484e+006 5.00384e+006 0.0) . . : Is there a possibility to look like this: (delimited with comma or blank field) 1 6500000.00 5000000.00 120.00 2 6511111.22 5022555.11 150.33 : : Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 And I saw that export txt file looks like that: 1 --> (6.47481e+006 5.00382e+006 0.0) 2 --> (6.47484e+006 5.00384e+006 0.0) . . : Is there a possibility to look like this: (delimited with comma or blank field) 1 6500000.00 5000000.00 120.00 2 6511111.22 5022555.11 150.33 : : Yep Lee MAc that is good, veeery good!!! I was searching that...Is there an option to put new renumbered points in some new layer??? Certainly - not a problem Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 Ok, give this a go - Note: Decimal Precision can be changed at the top [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:ptSort [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] dp ss file tmp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] dp [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [i][color=#990099];; <<---<< Decimal Precision[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] sort:def [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"POINT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] file [b][color=RED]([/color][/b][b][color=BLUE]getfiled[/color][/b] [b][color=#ff00ff]"Select File to Write"[/color][/b] [b][color=#ff00ff]""[/color][/b] [b][color=#ff00ff]"txt"[/color][/b] [b][color=#009900]9[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cnt [b][color=#009999]1.[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#ff00ff]"X Y"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tmp [b][color=RED]([/color][/b][b][color=BLUE]getkword[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Coord to Sort by [X/Y] <"[/color][/b] sort:def [b][color=#ff00ff]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] tmp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sort:def tmp[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] file [b][color=RED]([/color][/b][b][color=BLUE]open[/color][/b] file [b][color=#ff00ff]"w"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]vl-sort[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x1 x2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b] car cadr[b][color=RED])[/color][/b] x1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] sort:def [b][color=#ff00ff]"X"[/color][/b][b][color=RED])[/color][/b] car cadr[b][color=RED])[/color][/b] x2[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]Make_Text pt [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cnt [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]write-line[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] cnt [b][color=#009900]2[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]32[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] pt[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] dp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]32[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] pt[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] dp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]chr[/color][/b] [b][color=#009900]32[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] pt[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b] dp[b][color=RED])[/color][/b][b][color=RED])[/color][/b] file[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cnt [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] cnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]close[/color][/b] file[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Make_Text [b][color=RED]([/color][/b]pt val rot[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=#ff00ff]"PTSORT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]62[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] pt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSIZE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] val[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]50[/color][/b] rot[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]7[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSTYLE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]71[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]72[/color][/b] [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]73[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]11[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 Hey Lee Mac, cannot find a words to thank you for this...If you ever come to Croatia I'll buy the biggest beer you ever seen!! Quote
VVA Posted May 28, 2009 Posted May 28, 2009 Layer NewNumberPoint (defun c:ptSort (/ ss file tmp) (vl-load-com) (or sort:def (setq sort:def "X")) (if (and (setq ss (ssget '((0 . "POINT")))) (setq file (getfiled "Select File to Write" "" "txt" 9))) (progn (setq cnt 1.) (initget "X Y") (setq tmp (getkword (strcat "\nSpecify Coord to Sort by [X/Y] <" sort:def "> : "))) (or (not tmp) (setq sort:def tmp)) (setq file (open file "w")) (foreach pt (vl-sort (mapcar (function (lambda (x) (cdr (assoc 10 (entget x))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (function (lambda (x1 x2) (< ((if (eq sort:def "X") car cadr) x1) ((if (eq sort:def "X") car cadr) x2))))) (Make_Text pt (rtos cnt 2 0) 0.0) (write-line (strcat (rtos cnt 2 0) " " (apply 'strcat (mapcar '(lambda(x)(strcat (rtos x 2 15) " ")) pt)) ) file ) (setq cnt (1+ cnt))) (close file))) (princ)) (defun Make_Text (pt val rot) (entmake (list (cons 0 "TEXT") [color="Red"] (cons 8 "NewNumberPoint") ;_New number layer[/color] (cons 62 2) (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) (cons 71 0) (cons 72 1) (cons 73 2) (cons 11 pt)))) Quote
goldy2000 Posted May 28, 2009 Author Posted May 28, 2009 Thanks VVA...these lisps are exactly I was searching for...Big hello to everyone from sunny Croatia.. Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 Lee Mac the fastest Hey Lee Mac, cannot find a words to thank you for this...If you ever come to Croatia I'll buy the biggest beer you ever seen!! Damn Lee! You're fast at that >. Thanks Guys, VVA> I just did it the simple way - I much prefer your method for turning the pt into a string using mapcar - much more succinct goldy> Glad it was what you were after - it wasn't too much trouble Quote
