(Defun C:DSS ()
(setq bnum (getint "\nEntre com um numero: "))
 (setq inum (itoa bnum))
  (Setq PT1 (GetPoint "\nPonto de Desapropriação: " ))
   (Command "-INSERT""PONTO" PT1 "1""1""0" inum inum "")
(while (/= nil PT1)
    (setq bnum (+ bnum 1))
      (setq PT1 (getpoint "\nEscolha proximo ponto: "))
(setq ptlist (append ptlist (list PT1)))
 (setq file (open (getfiled "Output file" "" "" 5) "w"))
  (write-line (strcat (rtos (cadr PTLIST)) "," (rtos (caddr PTLIST))) file)
   (close file)
(Princ)
That's a lisp who i want to take every "insert point coordinates", and put it on a ".csv file, who i will open in excel and generate a table of coordinates... But is not working... I need some tips, i do not want the solution.I want to make it from my own. If someone could help me, i will be very grateful.
PS: Excuse me for bad my English
Did you not want to expand on the LISP I posted previously in your other thread to help you with the one above:
(defun c:DSS  (/ oldatt bnum pt1)
 (setq oldatt (getvar "ATTREQ"))
 (setvar "ATTREQ" 1)
 (if (and (setq bnum (getint "\nEntr com um numero: "))
          (or (tblsearch "BLOCK" "PONTO")
              (findfile "PONTO.dwg")))
   (while (setq pt1 (getpoint "\nPonto de Desapropriação: "))
     (command "-insert" "ponto" pt1 "1" "1" "0" (itoa bnum) (itoa bnum) "")
     (setq bnum (1+ bnum))))
 (setvar "ATTREQ" oldatt)
 (princ))
Perhaps something like this to write to file?
(defun c:DSS  (/ oldatt file bnum pt1 ptlst)
 (setvar "ATTREQ" 1)
          (setq file (getfiled "Output File" "" "csv" 9)))
             ptlst (cons pt1 ptlst))) ; Add the point to the list
     (setq file (open file "w")) ; Open the file for writing
     (mapcar
       (function
         (lambda (x)
           (write-line
             (strcat (rtos (car x)) "," (rtos (cadr x))) file))) ptlst)
     ; Write each pt in the list to the file
     (close file)))
  ; Close the file
 (princ))
It's advanced for me, ahaha, but i can understand your lines...I already have 1 lsp with your increment, and work very well!!! So, i want to increment more, and get a *.csv file with the coordinates. Can i take it using "append"?
what's wrong with my code?
"EDIT"= You are so fast,disregard the above text
this is definitely what I was thinking! Thank you very much. I do not even know this function lambda ...
Thanks :D
As for "lambda" it is what is known as an "anonymous function", when you want to perform a set of operations on each member in a list, you can combine a "mapcar" with a "lambda" function that is a generic example of the operation you want to perform... if that makes any sense... :P
i.e.
(mapcar '(lambda (x) (+ x 2)) '(1 2 3))
or
(mapcar (function (lambda (x) (+ x 2))) (list 1 2 3))
will return:
(3 4 5)
And so you can see that the generic function "lambda" has been applied to each member in the list, and the result is a list of the returns.
