brianhiroshi Posted May 28, 2009 Posted May 28, 2009 Hi, I was trying to do something like this: (setq dimension (getstring "\nType the value: ")) (setq pt1... (setq pt2... (setq old_dimpost (getvar "dimpost")) (setvar "dimpost" (rtos dimension)) (command "._dimlinear" pt1 pt2) (setvar "dimpost" old_dimpost) The problem is that the program still shows the original value of the dimension. As the dimpost variable is only supposed to be used to edit prefixes and sufixes it makes sence not to be able to edit the dimension. Is there a variable that I can edit so I don't have the real dimension but the typed one? Thanks Quote
Lee Mac Posted May 28, 2009 Posted May 28, 2009 Something like this? (defun c:dimov (/ dEnt tStr) (if (and (setq dEnt (car (entsel "\nSelect Dimension: "))) (eq "DIMENSION" (cdadr (entget dEnt))) (setq tStr (getstring t "\nType New Value: "))) (vla-put-TextOverride (vlax-ename->vla-object dEnt) tStr)) (princ)) Quote
brianhiroshi Posted May 28, 2009 Author Posted May 28, 2009 I don't think is exatcly this and because I don't know how to use the vla functions in lisp, but what I was trying to do is to get the dimension between two points and the dimension would already be done by the porgram. I don't know if I'm being clear... The problem really is that I don't know how I would aply this code showed in my program. Quote
Freerefill Posted May 28, 2009 Posted May 28, 2009 DIMPOST only inputs a prefix or suffix.. perhaps that could be the problem? The dimension will have whatever it measures, as is the default. Your code seems to be putting a number onto the end of it. Try typing in a few 1's when you run your code, the dimension should clearly have those 1's appended to it. Further, your code is putting a string into (rtos), whereas (rtos) is looking to turn a real into a string. That function shouldn't even -work-. Try using (getreal)? Hope some of that helps. ^^ Quote
Commandobill Posted May 28, 2009 Posted May 28, 2009 Run this see if it fits your needs. dimlinear requires 3 points... atleast in 2008 (defun c:dimov (/ dEnt tStr) (setq pt1 (getpoint "Specify first extension line origin: ")) (setq pt2 (getpoint "Specify second extension line origin: ")) (setq pt3 (getpoint "Specify dimension line location: ")) (command "dimlinear" pt1 pt2 pt3) (if (and (setq dEnt (entlast)) (eq "DIMENSION" (cdadr (entget dEnt))) (setq tStr (getstring t "\nType New Value: "))) (vla-put-TextOverride (vlax-ename->vla-object dEnt) tStr)) (princ)) Also freerefill... get back to work... lol Quote
Freerefill Posted May 28, 2009 Posted May 28, 2009 Run this see if it fits your needs. dimlinear requires 3 points... atleast in 2008 (defun c:dimov (/ dEnt tStr) (setq pt1 (getpoint "Specify first extension line origin: ")) (setq pt2 (getpoint "Specify second extension line origin: ")) (setq pt3 (getpoint "Specify dimension line location: ")) (command "dimlinear" pt1 pt2 pt3) (if (and (setq dEnt (entlast)) (eq "DIMENSION" (cdadr (entget dEnt))) (setq tStr (getstring t "\nType New Value: "))) (vla-put-TextOverride (vlax-ename->vla-object dEnt) tStr)) (princ)) Also freerefill... get back to work... lol Funny how you tell ME to get back to work when I simply wrote up a few suggestions and you took the time to analyze and edit his code. YOU get back to work. .... BLADOW!! Quote
Commandobill Posted May 28, 2009 Posted May 28, 2009 YOU get back to work. I'm your boss for the next 3 minutes... lol Quote
brianhiroshi Posted May 28, 2009 Author Posted May 28, 2009 Yes, that's the porblem, dimpost only adds prefixes and suffixes. The rtos works, but it does what you said, the code puts the number which is in dimension right after the real measure. What I would have to do is to find out how to "erase" the real value and keep only the alternate value. This would be very easy to do in AutoCAD, but it's been a big problem lately in Lisp :-) Quote
brianhiroshi Posted May 28, 2009 Author Posted May 28, 2009 I've put it into my code and it worked! But the user still has to type the value. In my case, this value would still be predefined at the beginning of the code. Is there a way to use it? Quote
brianhiroshi Posted May 28, 2009 Author Posted May 28, 2009 Sorry people, problem solved! Thanks for the help Quote
