Copy With Base Point - Paste to Original Coordinates
This question is to all Civil 3D 2010 users,
Have you encountered any problems with the Clipboard functions? Here what happens, when I copy an objet with base point and try to whether Paste it as block or Paste it to Original Coordinates, theses two options are not available in the Clipboard menu. Does this occur to every body, is this a "normal" problem with C3D 2010?
If your doing copy with base point, i always choose 0,0 if i need it to go in a specific place, and i just use ctrl+v and type in 0,0. Thats the point of a copy with base point. But my "paste to original cords" is grayed out too... ive never used it though.
  • 4 years later...
Use the word command.
Type on Command line: "PASTEORIG", "PASTEBLOCK"
The PASTEORIG (Paste to Original Coordinates) command will not work in the drawing from where you copied the entities. For this reason the menu item is disabled.
