How do I convert an Autocad file to ArcGIS? It imports okay, but only as a single layer, although there were many layers in the original Autocad. How do I separate the layers?
Maya
What version of ArcGIS are you using?
You should be able to bring in the cad file and display all the layers. Then you can filter and export to shape files if I remember correctly...
