Rotate a view in a viewport
  • 3 weeks later...
  • Replies 22
  • ReMark
    7
  • jvwarnick
    2
  • miscille
    2
  • tree-geek
    2
I use LT and DVIEW command disappeared from that in about 2009. Previously we had used DVIEW extensively. On the plus side, that was what launched me into macro writing.
MVSETUP also is not in LT.
Since you are using AutoCAD 2013 have you ever tried resetting the value for the system variable I mentioned previously then using the Rotate command. Two steps instead of seven.
just found out! great update
only one inconvinience: the shape of vp changes with rotation too. have to reshape it to rectangle
