How do i create a LISP so that my polylines linetype will set to 'DOT' then the command line prompt me for a Global Width. This is basically for converting more than 1000+ polylines to show a more detailed route of flexible ductwork. From what i understand this should be quite simple to create, it would benefit me massivley and is probably a good one for someone un experienced like myself to make. I just need some guidance & explination of varibles ect. Cheers guys.
All help welcomed.
Rergards,
Z
You could do a command-line-cop-out and write a very simple LISP using (command "chprop"). The hard part would be creating your selection set, that is to say, determining what polylines need to be altered.
No error trapping but:
(defun c:plyupd (/ ss wid ply)
 (vl-load-com)
 (if (and (setq ss (ssget "_X" '((0 . "*POLYLINE"))))
          (not (initget 5))
          (setq wid (getreal "\nSpecify Global Width: ")))
     (setq ply (mapcar 'vlax-ename->vla-object
                       (mapcar 'cadr (ssnamex ss))))
     (mapcar
       (function
         (lambda (x)
           (vla-put-ConstantWidth x wid))) ply)
     (mapcar
       (function
         (lambda (x)
           (vla-put-linetype x "DOT"))) ply)))
 (princ))
You're more machine than ReMark, Lee. :shock:
What does
(lambda (x))
denote? :huh:
Cheers again dude!:wink:
What does
(lambda (x))
denote? :huh:
That denotes an anonymous function that I am applying to every member in the supplied list through mapcar. :)
Happy to help out mate,
Lee
:huh: OkOk.. that all makes sense until
mapcar
:lol:
last definintion of the day, promise :oops:
Also, is there a way so that the command line will remember my last input when specifying global width and use that upon hitting return/right click? Oh, and set layer? :cute:
Z
What does
(lambda (x))
denote? :huh:
Mapcar will apply a function to every member of a list and return a list of the results... all this is in the Visual LISP help in ACAD you know...
 (vl-load-com)
 (or *wid* (setq *wid* 1))
          (not (initget 4))
          (setq wid (getreal
                      (strcat "\nSpecify Global Width <" (rtos *wid*) ">: "))))
     (or (not wid) (setq *wid* wid))
     (mapcar
       (function
         (lambda (x)
           (vla-put-ConstantWidth x *wid*))) ply)
     (mapcar
       (function
         (lambda (x)
 (princ))
^^ there you are...
NiceyNicey! I'm learning.. but slow :\ I'm more studying what LISPs you've wrote upon request and breaking them down into things i can use and trying to apply them to my own experiments :P
Z
Z
Thats pretty much exactly the way I learnt :D
Lee
