RONIN Posted June 4, 2009 Share Posted June 4, 2009 Greetings, Has any one been experiencing problems with OSNAPs in 2010? When I model piping, the OSNAPs only picks up on the center of the pipe, even though it should recognize nodes, tangents etc. I have tried turning specific snaps on/off, changing views, auditing/purging, reboot...Nothing works Thanks for the help. R Quote Link to comment Share on other sites More sharing options...
rkent Posted June 4, 2009 Share Posted June 4, 2009 You are using MEP so some osnaps may not work for MEP objects, go to options and look for the osnaps specific to MEP objects. I am using Mechanical 2010 and have not had any trouble snapping to extruded circles, as an example. HTH Quote Link to comment Share on other sites More sharing options...
Zorg Posted June 9, 2009 Share Posted June 9, 2009 Check your block database and ensure the MEP objects are set up correctly, i suffered this and found my entire services platform was not straight but rather quadrants were connecting to each other as they pleased. Quickly rectified it by edting the pipe files themselves Quote Link to comment Share on other sites More sharing options...
